8.8 fbody rear
Old Sep 6, 2011 | 10:07 AM
therobman's Avatar
Default 8.8 fbody rear
its a 8.8 rear with the 10 bolt axle tubes pressed and welded in. It is factory length and you will be able to use your factory brakes. it has 4.10 gears in it with a 28 spline diff with the center welded together acting like a locker with 28 spline factory axles. also comes with a set of 3.73 gears and a 31 spline diff all you would need are 31 spline axles. It is a ladder bar set up with g force suspension control arms which were 450-500 themself. also comes with a aluminum driveshaft with the correct u joint ready to go just needs backing plates. asking 1000 im selling it to buy a bike. i can get more pics if needed its already out the car ready to go. there are more pics of this same set up in this thread with better pictures.
https://ls1tech.com/forums/suspensio...ion-setup.html
Old Sep 6, 2011 | 08:41 PM
2kblackgtp's Avatar
sent you a pm
Old Sep 7, 2011 | 08:30 AM
therobman's Avatar
pm returned upp
Old Sep 11, 2011 | 09:23 PM
therobman's Avatar
bumppppp
Old Sep 15, 2011 | 03:32 PM
therobman's Avatar
$950 bumpppp
