Forged 383 ls1 and built 6Speed!!!
Eagle LS1 4.00-Inch Stroke Crankshaft, 24X Tooth Reluctor
Eagle LS1 6.125 H-Beam Connecting Rod Set with Upgraded
ARP 2000 Rod Bolts, 2.100 Crank Journal, .927 Wrist Pin
Diamond Racing Forged Flat-Top Piston Set: 3.905" Bore,
4.000" Stroke, 6.125" Rod Length, -2cc Valve Reliefs; .927" x
2.500" Wrist Pins Included
Texas Speed & Performance Exclusive Total Seal Ring Set:
3.905" + .005", 1.5mm AP Stainless Top, 1.5mm Napier 2nd,
3mm Oil
Clevite LS1 H Rod Bearing, Per Bearing
Clevite H Main Bearing Set, For LS1 Stroker Applications
Texas Speed & Performance 7.40 Chromemoly Pushrod, Per
Pushrod
Melling High Pressure Oil Pump, 1997+ LSx Based Vehicles
Comp Cams OE-Replacement Hydraulic Roller Lifters, SBC &
LS1
ARP main studs and head studs
ported ls6 intake
bbk tb
80lb injectors
fast fuel rails
motor has less than 1500 miles on it has 317 heads with fresh valve job prc dual gold extreme springs cam is epp blower cam there a few other things im forgetting im aksing 4500 for the COMPLETE MOTOR OR WILL SELL AS A SHORTBLOCK i will sell the intake and the rest of it AFTER the shortblock is sold
TRANS
6 speed with 40k miles on it was built as a stage 2
has 1-2 2-4 bilet syncro keys
bronze fork pads throughout
steel 3-4 shift fork
bronze shifter cup bushing
carbon/kevlar blocker rings
CLUTCH
monster 11" ceramic great clutch only 600 miles on it comes with the 28lb flywheel
Tick master cylinder
PRO 5.0 shifter
6 speed crossmember
i will sell the 6 speed as a swap until the trans would be sold i have everything except for pedals to do a swap i can also include the wiring harness for the right price
looking for 1800 for the swap
only interested buyers with money contact me please thanks
3mm Oil
Pushrod
LS1
ported ls6 intake
bbk tb
80lb injectors
fast fuel rails
TRANS
CLUTCH
PRO 5.0 shifter
6 speed crossmember
