88 mustang notch roller
Old Jul 4, 2012 | 10:08 AM
suicidal racing's Avatar
Default 88 mustang notch roller
my car i was doing is forsale.I have a open ct title for it and bill of sale which i will give you along with new bill of sale from me.Was going to be track only deal so never cared about the title in my name..I work weekends and nights now so i have no time for the track.
3400$ gets it.i have alot more in it then that.as you can see by all the new parts on it..my goal with this car was it to be very light,it was getting a built ls1 in it an was looking to be under 2500# with out me.
will trade for a malibu,gen 1 s10,nova,chevelle,vega or camaro rollers or maybe complete depending on what it is.
body
car has no rust holes or dents an has factory glass
has a alum deck lid that just needs to be cut in.
Doors have been cut and lighted to the extreme with lexan bolted in..doors are around 35#s each now,i have stock glass still and believe the inner steel panels if some one wants to weld them back on..door panels can still be hung with out them though.
3" bolt on glass hood
car has bumper covers but no bumpers under it nor mounts
have rear tail light housings
front have no lights but black head light covers
chassis
Car has a 6pt
tube style weld in frame connectors
suspension
front
aje uni k mem,i have chevy mounts that fit sbc,bbc an lsx
upr lower a arms
strange adj shocks and coil over setup
qa1 14"x130# coil springs
new upr caster camber plates
stock mustang steering rack with looped hose
rear
upr double adj uppers
upr single adj lowers
stock v8 coil springs with 3/4 coil cut
stock shocks
rear end
8.8 rear end
sn95 caliper brackets an brakes,just need hub centric spacer
moser 33 spline axles,5 lug wit 1/2 studs
moser c clip elems
moser full spool
motive 3.73 gear
stock diff cover
brakes
linc 5 lug rotors an stock stang calipers
sn95 disk stuff for conversion on the rear
areospace manual master cylinder brake kit,pedal drilled already though.
all brake lines are off,was putting all new lines in the car
interior
has stock gutted black dash,its just the shell
stock stripped stearing column with grant wheel
kirkey prostreet seat 17.5" wide with black seat cover
holcomb steal seat mount
have now out dated simpson 5 pt cam loc harness for the car.
black door panels
have back seat plastics that are grey..
Rims
weld pro star 5 lug rims powder coated semi flat black
15x3.5 rims with good yr front runners that have half life left
15x8 rims with mt 28x10.5 stiff slicks,only have 10 1/8th mile passes on them
electrical there is none in the car,believe i still have the front head light harness and i cut 2 plugs off the rear harness to keep an wire in for tail lights at the track.
fuel nothing is plumbed in the car,,was going to use a front mount set up and a 3 gal alum upright cell with fittings gos with the car.also have stock tank that i pulled out of it if some one wants that.
car is located in springfield,ma..heres some pics an number names tony 413-five19-6268 text or call if i dont answer leave a message an ill get back to you as soon as i can.thanks
pic
Old Jul 5, 2012 | 09:59 AM
will sell the the chassis with out the complete rear end/sn95 brakes an rear rims/tires for 2400$ you will still get uppers/lowers an springs..or i can pull more parts off an do what ever combo..would really like this gone
Old Jul 5, 2012 | 11:20 AM
BlackScreaminMachine's Avatar
Internet Mechanic
So for a Motor/Trans, Wiring, and if the buy wants a paint job (i.e. Just primer it) you have a race car, not bad.
Old Jul 6, 2012 | 12:32 AM
pretty much,needs pluming an cell mounted..most probably wont want a front mount cell...but they can always sell or trade..wiring i was getting a arc8000 panel for it..simple an easy..then they can put the rear shocks of there choice in it for there app..
theres other lil things but it all depends on persons goal and pref.
