6l80e
Old Nov 26, 2012 | 03:03 PM
dropedss86's Avatar
Default 6l80e
I have a awd 6l80e I was told it was out of a 09 escalade with 32k on it. Need dipstick I have eveything else I would like to get 1000 for it
Sorry this tranny is big so no shipping I am 10 minutes south of Philly
Old Nov 27, 2012 | 08:23 AM
dropedss86's Avatar
24238076 - Turbine shaft seal - $16.62
24224675 - Tailshaft extension gasket - $4.65
24224676 - Tailshaft extension housing - $113.12
24226707 - Rear bearing retainer - $19.75
24233898 - Rear bearing retainer seal - $18.60 - these 2 come together as one piece even though you have to order them separately.
11515768 - Bolts for tail housing x 6 - $0.85 each
24239394 - Rear 2wd output shaft - $182.98 - To install this piece, the trans has to be completely disassembled and put back together
since it's the first piece in and last piece out, may as well put new clutches in while you have it apart
24224668 - Rear seal bearing - $10.25 - this is optional, if it's still good when you rebuild the trans, then it is not needed
15813693 - 2wd transmission mount - $22.36
11517827 - Transmission mount bolts x 2 - $4.46 each
These are the parts to convert it to 2wd and I had a local shop tell me they would install it all for 250
Old Dec 1, 2012 | 09:47 PM
dropedss86's Avatar
or trade for rear anything but 10 bolt prefer 373 gears
