Will it pass tech at NED?
Car is an Ls1/t56 89 rx7 with re-located battery and a fuel cell
I've been going through the car and I got the clutch safety switch working, I am going to install a radiator overflow and I took the fuel cell which used to be in the back of the car and put it under the car and mounted it with some 3/8 threaded rods and 2 peices of 4" wide 1/8th in flat stock.
I also got the battery mounted in an NHRA approved box with vent tube exiting the vehicle. Obviously I needed an emergency shutoff switch which I have mounted and wired but havent labeled yet.
Car will be running nitto drag radials and and has no DS safety loop although from my understanding I dont need one unless I'm running slicks.
Here are some pics of my setup, in the back of the car I am missing a panel about 6" by 6" that used to cover the fuel pump assembly. I am trying to find a panel from another car but I may not have it by track day. I wonder if they will fail me because of it.
Only thing I can think of that I need is a helmet. Can anyone think of anything else?
I also would like to hear where you guys got your helmet. Doesnt seem like theres any place locally where I can try some different brands on.
Thanks guys and I hope to see you guys at the track this wed/Friday night, we'll see what I can get out of this thing.
-Josh
I am also gonna be using the helmet for SCCA events but I think NHRA rules are more strict so whatever works for the dragstrip should work for autox and roadcourse too.
be sure to lable theshut off, they will bust your *****.
if you have seatbelts good, if you have harnes be sure to have them 2 years old or newer. no cracked windsheild, all lug nuts etc etc etc
goodluck and good luck running that car in the next couple weeks. no track prep, cold moist temps. maybe for seat time as the street is more dangeros, but if the car doesnt run what you are hoping, dont get yourself down.
" loop required on all entries running 13.99 1/4mile or 8.59 1/8 mile or quicker that utilized racing slicks. drive shaft manditory on street tires at 11.49 1/4 and 7.35 1/8 or quicker"
thats right from the 09 rule book. so you should be ok depending on mods etc.
For seat belts I am just using lap belt part of couple harnesses I got. The factory seatbelts were junk and were scrapped before I got the car. I believe the belts may be past date I am hoping they dont check if I am using just the lap belts.
The cell is vented and thats the roll over vent where the blue 180 degree AN fitting connects. That goes to a hose through a hole in the floor out the bottom of the car.
I am going because I need the seat time. Even with the best track/weather conditions I'de still be more than a second off the potential of the car I bet. This is the first time I've owned a manual tranny car and obviously first time I've raced one. So the car needs driver mod BIG time!
http://www.jegs.com/webapp/wcs/store...oll+over+valve
if the cell is in the car atall it needs to be isolated from the drives compartment with a box or "wall"
I got the cell with the car but I'm 90% sure this is the cell
http://store.summitracing.com/partde...5&autoview=sku
You can see there are 2 10an fittings on the top of the cell, one of them is a vent, to fit the cell under the car I had to cut some 1 in holes for them to come up through.
Do you think I'll be ok with the harnesses or should I say lap belts?
as for the belts, if i had to guess id say they will smile and wave you good bye with just lap belts. i could be wrong tho. i ran them in my 14 sec truck (it came from the factory with them tho) and that was 10 years ago+ when things where allot more laid back. ca;ll the track tomorrow and ask joe.
Wtf that leaves me with no options. The factory belts were crap. I put in a lap belt thats no good.. a full harness without a cage is dangerous. .I meen its starting to **** me off. How much **** I've had to do and re-do over and over and how much money I've wasted doing it just to fit the rules
Not mad at you just pissed in general
Just another thing to add to the list to buy and instal. I'll have to see how much of the factory belts I have left and what it would take to put them back in place
is the young grasshopper coming along? or did i just get lucky?
haha love ya brad lol
