Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Big thanx 2 Eastside
Old Oct 11, 2009 | 05:24 PM
INTENESS's Avatar
Default Big thanx 2 Eastside
Brought the car up to eastside,cause my rear called it quits 12 bolt with a true trac and 31 spine axles.Turns out one of my axles was all splines was all twisted up and bent.This will explain why it was not stay staight going down the track.So I upgraded to a light weight moser spool and 35 spline gun drilled axles stayed with 410's.Car feels so much better like its putting the power to the ground alot better.Gears hardly whine drive fine on the street got use to already.Thanx Kenny,Gary and my man Sean.
Old Oct 11, 2009 | 06:47 PM
SSPerformance's Avatar
going to any atco rentals
Old Oct 11, 2009 | 06:51 PM
SPRSPT's Avatar
As allways good to see ya Davey. Hope everything works out for the 24th it should be a good day.
Old Oct 12, 2009 | 11:01 AM
Noyzee's Avatar
8 second mod
spool is the only way to go once you start making big power. thats for sure
