Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Need advice on exhaust build
Old Oct 23, 2009 | 07:53 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Need advice on exhaust build
Been planning in my head of a exhaust build on my car for a couple months and think over the winter im going to start getting the parts for it. First off is Long tube headers of course. Now after this i dont know what i want to do. Wanting to do sidepipes just after the door right before the rear tires. Picked as Tips. Want to see if i can get the ends cut at a 45 and oval inlet. The next thing is how to hang the exhaust from the tip back. Ill be using oval tubing right after the collectors for the headers so ill be gaining about a inch from the ground. I was thinking of just welding them right to the body but i dont know if that would break my headers and if so would adding flex tubing right after the headers help that? Also if i weld it to the body am i going to have lots of vibrations? Keep in mind down the road ill be adding a 427 LSx engine to this with most likely a pretty big cam :p.
PS also trying to find low profile oval mufflars
Old Oct 23, 2009 | 10:07 PM
Ping King's Avatar
run a flex pipe if you want to bolt them right to the body. I ran side exhaust for a while on my car. its a tight squeeze but doable.
