Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Braking Issue
Old Nov 23, 2009 | 04:54 PM
Weist's Avatar
Default Braking Issue
Vehicle: 1999 Pontiac Trans Am
I've noticed that when I get my vehicle up to a high speed (80 MPH or Faster) that it has a hard time coming to a complete stop quickly. It almost feels likes my brakes are skipping or not catching with the rotors. The pedal is tight and really doesn't have any play. When I press it all the way to the floor it keeps rolling (not stopping to potential). I don't know if I have a bad caliper, Air in the ABS system, need new brake pads or etc. The pads are only about a year old. The rotors seem in good shape not scored. I havn't touched the fluid since I bought the car about 2 years ago, so that could be a potential problem.
(I had my buddy take me for a ride in his car and brake fast and it almost comes to a complete stop in no time, where as mine takes longer) Just seeing if anyone had this problem and how they resolved it!!
Old Nov 23, 2009 | 06:13 PM
Slowhawk's Avatar
LS1Tech Sponsor
Try pulling the fuse for the ABS system and give it a try.
Old Nov 23, 2009 | 06:24 PM
Weist's Avatar
Do you think it could be rotor warp??
Old Nov 23, 2009 | 10:09 PM
Formula413's Avatar
With warped rotors you would feel the shake whenever you tried to brake at high speed. I'd like to see what people have to say, because my car's brakes feel weaker than I think they should.
Old Nov 23, 2009 | 10:36 PM
massls1guy's Avatar
I wonder if you have one or more frozen guide pins. When you did the brakes last time did you replace the guide pin seals and clean/lube the pins good?
Old Nov 24, 2009 | 09:38 AM
98hardtopSS's Avatar
My brake pedal doesnt go anywhere near the floor no matter how hard you push it. Are you sure they are bled correctly? Did you disconnect anything when you did the brakes? Make sure the reservoir is filled...any lights on? Is the ABS engaging?
Old Nov 24, 2009 | 04:28 PM
Brakemotive's Avatar
Sounds like a hydraulic issue to me. I would check the fluid level in the MC first and follow up with a fluid flush. Also, have you recently driven the car hard, or encountered a panic stop situation? Pad glazing over is also a possibility.
