Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Custom Audio Help
Old Mar 24, 2010 | 10:18 PM
99TransAm GF's Avatar
Default Custom Audio Help
Looking to redo the audio system in my '99 trans am. Definitely looking to do a custom system, the stock speakers are pretty much shot. I really don't want to spend more than $350. I already have an aftermarket head unit receiver. Anyone know someone good to use or what has sounded good?
Old Mar 25, 2010 | 09:21 AM
98hardtopSS's Avatar
Check out Kee Audio. They are a sponser on the site and have pre-determined packages that look great. Def. worth a look. I will be going that way at some point.
http://www.keeaudio.com/fbodyspeakers.html
Old Mar 25, 2010 | 09:44 AM
DannoWS6's Avatar
Those speakers are a better match with the stock monsoon system. OEM speakers like a 3ohm load with that head unit while most aftermarket offer 4 as the standard. I had infinity kappas (3ohm) in my bonneville on the stock head unit for that reason.
That is a good package though and it will work, but since you have an aftermarket unit sky's the limit. I find stuff cheap on Amazon when I'm looking around.
Old Mar 25, 2010 | 12:26 PM
I have an Alpine in my car and the improvement in sound quality over the stock was amazing. Sounds OK with the stock setup. I would love to update my speakers as well but I just hate cutting wires.
Old Mar 26, 2010 | 12:08 AM
My biggest issue at this point is being on a budget. I looked at Kee audio, and they have some great packages but I think it is a little more than I'm looking to spend. The other thing is that I don't have the monsoon face anymore, it's an aftermarket one. Is my best bet going to be buying the stuff individually or as a package deal? Any suggestions? Thanks for the help.
Old Mar 26, 2010 | 12:44 AM
whitew01ws6's Avatar
i have a big stereo in my trans am. i have found just a set of co-axles in the back behind the seat and a nice set of sepereates of front small sub and a amp to power them all. its nothin over the top but it sounds great. if u have anymore specific ?s just PM me.
Old Mar 26, 2010 | 10:10 PM
Anyone know if the Kee Audio package for Firebirds that is listed as being for Monsoon systems will work with an aftermarket face unit?
Old Mar 29, 2010 | 06:14 AM
DannoWS6's Avatar
Yeah they will, they are probably a lower resistance at 3ohms though, but your current setup is the same. You could ask them. Your headunit might run a little warmer and it will sound louder than a 4ohm setup, but it should handle it, like I said it is now. I still think you could go online like Amazon and find the fronts, mids, rears for around $200.
When I had the bonneville I got Infinity Kappas , 2 tweeter, 2 6.5's, 2 5.25's, 2 6x9,s. So six speakers for about $240.
