I need recommendations for Engine work on a L92
Katech A1 rod bolts
ARP Head Stud kit
ARP Main bolt kit
LPE 3 Bolt conversion kit
3 bolt Comp Cam
Powerbond underdrive pulley
Edelbrock 2 piece timing cover using a seal from a LS3 cover and sensor from the VVT cover
- hone, align or deck the block as needed.
Yella Terra 1.7 rockers on a set of TFS/TEA LS3 heads.
Install a smaller power steering pulley
I have all the parts, bolts,studs, gaskets. The L92 has original heads on it, no intake, no fluids, only VVT water pump. The L92 can be put on a pallet, currently sitting in the GTO.
Engine is located in Glen Cove, NY 11542
any shop recommendations and cost estimates?
Thanks
My guess is a machine shop told you it was needed - Yes - head and main studs will cause the block to distort differently when torqued, and Aftermarket Rod bolts will cause the big end to distort. But youre talking 0.000X".
A friend recommended McBetts Racing Assocs. - Holbrook, NY any one ever used them?
I am sure I am using the wrong terms. I thought you had to make sure the block was square or in tolerance because the factory block could be off?
It is a factory block, don't you have to do some machine work when you replace the rod bolts or main bolts?
What about the heads don't you need to make sure the gasket will seal correctly?
thanks
