MD inspection?
As a regular inspection
will not pass. Actually it's a fed offense to remove emissions equipment (if not replacing) or so I understand. You run the car at 2500rpm for 30 secs and then run it at idle for 30 secs.
For OBD he said they check for cats, check the gas cap, and plug into the OBD port. They look for codes and the readiness state of the ecm.
