Bad fuel pump/filter?
Bad Filter would make the car feel restricted or down on power. If you scanned it, the PCM would be correcting or asking for more fuel to compensate.
Bad Gas if you have not had your high/low octane tables matched for tuning purpouse, then it should not be as noticable as a stumble, I would have you see: Bad Filter. As timing would be dialed down.
Bad Pump until you get a FP guage on there and drive it while putting a load on the motor, you wont know if its a pump. On old LT1 cars pumps and opti sparks showed similar manners.
IMO it is a wire or plug.
