Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Squeak and cant figure it out
Old Feb 9, 2011 | 01:47 PM
USCGMEATHEAD's Avatar
Default Squeak and cant figure it out
so I installed a new rack and pinion this weekend got an alignment and drove home 300 miles. came to a stop light and herd a squeeking sound coming from the engine bay. I popped the hood to see what it could be and it sounds like a belt squeeking but i replaced the belt when I did the h/c install. The squeel still happends when I give it gas. Could it be the power steering pump. The hoses are hooked up right and everything. Here is a link to the video I took. I cleaned the belt and its still making the noise. Thanks for any help
http://www.youtube.com/watch?v=0z_2DBwd980
Old Feb 9, 2011 | 01:51 PM
6speedt/a's Avatar
Have you check the ps fluid level since you put the rack in? also check the tensionor pully and idler pully right next to the ps pump. Pull the belt off and spin both of then is you hear any grinding replace them. also do the same thing with the a/c pully and idler.
Old Feb 9, 2011 | 01:56 PM
ANTICOP RAM AIR's Avatar
first randomly squirt ws40 on the back of each pully and see if that changes the sound.. if not, take off the belt and run it.. rotation sounds like its could be from balancer... if you still hear noise check that
Old Feb 9, 2011 | 02:11 PM
Yes I checked the ps fluid its still full. Ill check the tensioner and balancer and see if thats it. thank yall for the information
Old Feb 9, 2011 | 04:16 PM
Formula413's Avatar
There is a thread in the general maintenance forum about how to re-pack the idler pulley bearings with grease, that might fix your problem.
Old Feb 9, 2011 | 04:20 PM
babbage1109's Avatar
I replaced my belt and water pump maybe 10000 miles ago. And still if it's rainy out or something the belt will squeak. But it squeaks where the print runs under the pump. It's not as fast as yours is going I'd say it'd be a pulley
