Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
C5 fuel gauge issues??
Old Aug 4, 2011 | 07:25 AM
skeeters65's Avatar
Default C5 fuel gauge issues??
Is it common for the fuel gauge to suddenly drop to E on longer drives?
Car is a 2001 C5??
If so how do you fix it?
Thanks
Old Aug 4, 2011 | 07:46 AM
mikep2002's Avatar
You can easily check the float by pulling the sending units out of both tanks in the wheel wells. Start there before ripping apart the dash. And check grounds also. Number one problem with c5s...
Old Aug 4, 2011 | 07:51 AM
skeeters65's Avatar
Thanks dude I did a google search after I posted this.
I guess it is quite common. Techron seems to be the answer..
Thanks
Old Aug 4, 2011 | 09:09 AM
Slowhawk's Avatar
LS1Tech Sponsor
Very common problem.Take the assembly out infront of the driver rear wheel.Clean the swiper for the fuel sender. Simple but a pain in the ***.
Old Aug 4, 2011 | 09:58 AM
mikep2002's Avatar
U also do the same thing to the tank on the passenger side. The 2 fuel tank sending units talk to each other. If one or the other does not agree with each the will drop to E...
Old Aug 9, 2011 | 11:36 AM
nyg215's Avatar
I would try adding techron before pulling anything apart...it worked for me.
Old Aug 9, 2011 | 05:07 PM
C5kid's Avatar
^^^^ agreed. Make sure it's Techron fuel cleaner. I did this to mine and it fixed it right up.
