Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
better get Maaco?
Old Jun 11, 2014 | 01:26 PM
matt6822's Avatar
Default better get Maaco?
so I have a 2002 TA, black. Chips, scratches, and scuff marks all over car and some cracking in fiberglass hood. Tired of black, too much of a pain to take care of. Constantly dirty, covered in pollen, whatever. Thinking of going to some shade of blue, maybe electron blue. I have heard over the years a good amount of bashing about Maaco, but quite honestly I checked out one in Philly while at work and I took my time going over the finished look of 2 cars he had on the lot. Looked really good. It was a sunny say so I looked at various angles for swirls, fading, etc. No running, bleeding, blotches, etc. Instead of dropping ten grand somewhere, was wondering if they or anybody else around Philly area was a quality provider of a great paint job for a fair price that doesn't require a financial beat down. Opinions?
Old Jun 11, 2014 | 02:16 PM
Slowhawk's Avatar
LS1Tech Sponsor
Maaco has different levels.
Insurance cars get the quality work. The cheap specials they have get the paint slapped on.
Old Jun 11, 2014 | 02:53 PM
blknSS's Avatar
I am in the same boat with black. Terrible to take care of. Looks great when it is in top shape but my paint is almost 15 years old. Been garage all its life but still 15 years is hard to hide on a black car. The paint isn't in that bad of shape, its just the clear coat, so i have been on the "get it buffed and slap a few coats of clear coat on it" way of thinking. Not a paint guy so don't know how feasible that would be but i think it may be an option. Never had a car painted by Maaco, but i would like to hear some long term reviews of their work.
Old Jun 11, 2014 | 03:27 PM
Wheelman916's Avatar
This. Their cheap paint jobs are crap. No prep. Single coat color & clear. Over spray on exhausts, and sometimes tires and weather stripping.
Honestly, if you're dead set on doing a cheap Maaco paint job, take the time to sand and rattle can primer the car at home. Tape off weather stripping and stuff yourself. Send it in on 4 spare wheels. Take off your exhaust tips if you have clamp on tips. Bare minimum prep work can make that cheap paint job look decent.
If the car has been garaged its entire life, and the clear coat isn't oxidizing at all... You can definitely clean up swirls and light scratches with a decent buffing with compound and polish. You won't need to respray it. If it's never been buffed before, the clear coat has plenty of thickness left to work with. If the paint isn't bad, you can probably see a marked improvement skipping compound and just do a polish, and maybe follow up with a glaze.
Here you can see the difference with abused black paint, before and after compound and polish. No need for additional clear coat.
Old Jun 12, 2014 | 08:20 AM
DannoWS6's Avatar
You might be surprised how much you can get out of old paint.
As long as the paint is not failing, you can try to correct any oxidization, small scratches, RID's, etc.
If the paint is only failing on the hood (cracks) maybe just repaint the hood.
Skimping on a paint job you might regret in a couple years down the road, when its starts to look worse than it did before you painted it. If you go that route and also want to keep costs down, keep the color the same so you don't have to repaint door jams, under hood etc.
Old Jun 12, 2014 | 08:48 PM
murphinator's Avatar
good advice above , I used to do a fair amount of paint correction on the side , buffing ,waxing , wet sanding , etc... and I would add it may be worth spending for that so you know where you are really at , you may be able to narrow it down to just a panel or 2 that need actual paint work , then you may even be able to locate replacement panels in the same color if your patient as it will look presentable hopefully after buffing and at a minimum be able to afford a better painter since the area of concern will be smaller.
To do a color change properly is very costly , thick paint chips easily so the paint on the car really needs to come off or be sanded down substantially and to get color everywhere it should be to not be able to tell its been through a color change many panels exterior and interior need to come off and painstaking prep/tape work needs to happen.
