ls swap electronics/dash gauges HELP! tech help needed
im a tech, but not a fully experienced one. im past a novice level or weekend warrior but im no expert or ASE certified tech.
the car is a 72 nova with lm7 4l60e
psi conversion wiring harness and full autometer gauges (speedo, rpm, temp, volts, oil psi, fuel) stock pcm tuned by psi conversion as well
tanks inc and psi conversion fuel delivery system. need help with integration of the harness to the gauges so they function.
the hard part is done, i got the engine and trans in the car. i jus need help with the wiring, fuel delivery and installation.
the body harness of the car needs some TLC as well
if anyone is wiling to help, im in the NYC area, queens, zip 11357.
ill be willing to compensate fuel and or lunch for some help to get my project finished to at the LEAST get the engine started and the gauges work as well. everything else i can take care of on my own,
sincerely, a guy just wanting help getting his car up and running
u can reply to the forum thread or PM me and ill send my # over
-Mel
