Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Which head gaskets should I get?
Old Mar 21, 2022 | 02:05 PM
LGrock's Avatar
Default Which head gaskets should I get?
I'll get straight to the point. I have a 2001 5.3 ls1 vortec cast iron block that I'm taking the aluminum heads off of, to replace with 5.7 aluminum heads. Does anyone know if standard 5.7 headgaskets will work right off the bat, or do I need a specific gasket? Maybe I need to do work the cylinders before placing the new heads on? I've looked online and other forums but ha e only found info on 5.3 heads going onto 5.7 blocks.
Old Mar 21, 2022 | 08:15 PM
wannafbody's Avatar
Shoot Summit Racing or WS6 store an email.
Old Apr 1, 2022 | 11:21 AM
Summitracing's Avatar
LS1Tech Sponsor
You can run an LS1 head gasket on your LM7 that isn't a problem.
For head gaskets, we would recommend the Cometic .051" factory thickness CGT-C5475-051. Another option is the Cometic .040" CGT-C5475-051. Going with the .040" gaskets will bump compression about 0.3. That will also reduce the quench distance which will promote a better combustion cycle.
__________________
800-230-3030
www.SummitRacing.com
Old Apr 4, 2022 | 06:56 PM
swizcore's Avatar
Not to hijack but I accidentally ordered the head gaskets intended for '02 5.7L LS1 and mine is a '98 5.7L LS1 from a Corvette... Is this a no fly zone or not a big deal?
Old Apr 6, 2022 | 11:39 AM
LS1Tech Sponsor
If you have a '98 LS1 with perimeter bolt valve covers the '02 head gaskets will not work and you'll have a coolant leak. Fel-Pro offers their FEL-9284PT Perma-Torque MLS gaskets that will work for those older perimeter bolt heads. If you have center-bolt valve covers then you can use the NAL-12498544 '02 LS1 head gaskets.
__________________
800-230-3030
