Need help with cam position sensor light
I recently just installed a fitech ultimate ls intake manifold, 92mm throttle body , 36lb Injectors and fuel rails.
I also replaced both crankshaft sensors and and camshaft position sensors since I had the intake off.
Well the car fired right up but of course it took a second but now my SES light is on and it says it's the camshaft position sensors bank 1.
Do I have to relearn the sensors since I replaced them?
AND IS THERE A PERFORMANCE SOFTWARE THAT CAN TUNE AND RELEARN?
98 FIREBIRD TRANS AM 5.7L LS1
VORTECH RAM AIR SYSTEM
Fitech ultimate ls intake manifold
Fitech 92mm throttle body
Fitech #36lb injectors, fuel rails
TSP STAGE 2 CAM and springs
TSP long tube headers
Tsp y pipe
Tsp full catback
CAMERON POWERS TH400 reverse valve transmission
Hurst 1/4 stick
3800 stall converter
Ford 9in rear end
vikings coilovers fully adjustable suspension
