Slowhawk, Easterners - help with my car!!!
https://ls1tech.com/forums/gears-axles/304836-vibration-rattle-clunk-after-swapped-parts.html
1. The rear was not centered left to right. We had checked simulated level on the lift - but after driving and on the ground we moved the rear 3/4" to the right with the panhard rod. Major vibes and rattles gone!
2. Slowhawk - took your advice and did the angle again, just went to where it looked best and the car was really smooth now. Still noisy for me - making the rear seem bad so we put the BMR tq arm back in - PERFECT!! -1.5 degrees pinion angle, no more gear noise than my 10 olt and ZERO rattles, vibes or clunks
See you at LVD!!! THANKS FOR THE HELP
