First Mods!
First mod is B&M Ripper installed today along with an Amsoil transmission fluid swap. Second, third, fourth mods are 3.91s, Harrop rear cover, Crossmember bushings with Amsoil differential fluid (awaiting arrival from DiffTechnics in Austrailia). Can't wait to start heat cycles with the new gears . . .
But since I can drop a T56 and re-install it independently in the snow, I figured I could manage draining the fluid, fill'er back up and install a shifter!!
Thanks again. I will let you know when the Crossmember bushings and other parts come in!! Transmission seems smoother with the Amsoil in it!
The gears and such should be here on the 31st or so, hopefully get them installed shortly following if the price is right, otherwise waiting until late next month!!
Pretty much on a course to extinguish wheel hop and of course go faster!!
