Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Please HELP!!
Old Jul 6, 2005 | 02:10 PM
T/acruiser9's Avatar
Question Please HELP!!
Hey guys,
I'm looking for a little help w/ a lighting problem. My day-time running lights and front turn signals seem to be all messed up. First the driver side turn signal got water in it and neither the daytime running light or the turn signal worked. So I replaced the socket and the Daytime running light started working but the turn signal stopped and the passenger daytime running light stopped all of a sudden and the turn signal worked. I replaced the passanger bulb and the daytime running lights then worked but neither signal did. I then replaced the turn signal canester under te dash and now the signals work in the back but not the front.
Currently I no longer have Daytime running lights or front turn signals or front flashers. I looked at the schematics and it seems as though the day time running light module may be the cause. The GM dealers near me are ****** and no can give me a straight answer and just tell me its expensive. My NYS inspection ran out the end of June and i need signals to get a new inspection.
I am wondering if any one has encountered this problem or if they have any ideas for a temp fix just to get it inspected.
I am sorry if this is a re-post.....I havent been on here in a while and havent had much time lately to do ne research. I thank you guys in advance for any ideas or comments
Old Jul 7, 2005 | 10:13 AM
I still need some help guys ne ideas would be greatly appreciated
Old Jul 7, 2005 | 10:17 PM
'02 SLP#686's Avatar
Can you just try disconnecting it? It is right behind the radio (green clip I believe) This disables DRLs and the automatic headlinghts
Old Jul 8, 2005 | 10:04 AM
Thanks.... I will try that I just didnt know where the DRL Module was and I couldnt get an answer from any dealer b/c they want me to just bring it in
Thank you I will give that a shot
Old Jul 11, 2005 | 08:33 PM
OK I figured it out......It was the Day Time Running Light Module And Thanks cuz it was right there behind the radio.....For Now I bypassed it with 2 jumpers to get the signals to work
Old Jul 11, 2005 | 10:46 PM
Saweeeet
