Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Tracer??????????
Old Jul 19, 2005 | 10:17 AM
Noyzee's Avatar
8 second mod
Question Tracer??????????
Is it true???
my buddy called said he was going to pick it up???
if it is, give me a list of mods so i know what im dealing with, i know it will need a clutch because Brian cant drive. lol
but fill me in on specs so i know whats going on when it comes time to work on it. Thanks
Old Jul 19, 2005 | 10:52 AM
PurEvl's Avatar
clutch is fine...fairly new
spec 3i clutch
ported ls1 241 heads by ls1derfull
224 cam
12 bolt 4:10 with denny DS
ls6 intake
meizure electric waterpump
asp crank pulley
torque thrust two rims
lou short shift
flp headers ypipe with custom bullet catback
420ishhp 395-400 tq
BMR- Sway, torque arm, control arms, adj.panhard rod, adj Hals. subframe connectors, shock tower brace
marcel can chime in the rest or fix anything i got wrong or left out
Old Jul 19, 2005 | 10:58 AM
Slowhawk's Avatar
LS1Tech Sponsor
Or in short
It is built right, don't screw it up by touching it
Old Jul 19, 2005 | 10:59 AM
Tracer X's Avatar
LS1TECH Sponsor
Thanks Mike,
That's most of the mods off the top of my head. I have reciepts for all of the mods. My brain is fried right about now, but I'll post up if I remember anything else.
The car runs consistent mid 11s. WIth a best run of 11.6. I don't think that anything needs to be done to it at all. Just do me a favor and have the kid drive it more than I did.
Old Jul 19, 2005 | 11:02 AM
PurEvl's Avatar
for what its worth brad...this car goes 11.6-11.7 consistant with 1.7-1.8 60's It has NEVER and i mean never broken or been touched since the day it was done years ago. Other then the fast intake from my car. The kid shouldnt have to do **** with it unless hes gonna add more good stuff. Just FYI
Old Jul 19, 2005 | 11:07 AM
Noyzee's Avatar
8 second mod
Originally Posted by Slowhawk
Or in short
cool, thanks for the list
Mike, the cluch can be new, but he cant drive so he will wear it fast. lol
if he gets any money once he buys it i know a few things we will do, should put the car mid-low 11's
Old Jul 19, 2005 | 11:11 AM
Tracer X's Avatar
LS1TECH Sponsor
Yeah, he back shifted while he was test driving it with me! Well he should have a lot of fun with the car. It drives like stock, until you press the pedal!
Old Jul 19, 2005 | 11:17 AM
Noyzee's Avatar
8 second mod
he needs some practice, and he will probably brake somthing, not be able to fix it, and i will by it from him for short money, fix it, swap the cam, put a 125 shot on it and make it my street beater! lol
'02 SLP#686's Avatar
Marcel, you get scared I was going to beat you? Or something better in mind?
Old Jul 19, 2005 | 11:20 AM
Noyzee's Avatar
8 second mod
yhea, his wife
Old Jul 19, 2005 | 11:21 AM
PurEvl's Avatar
with a big tire an you driving it will go below 11.5 right now brad
Old Jul 19, 2005 | 11:22 AM
Tracer X's Avatar
LS1TECH Sponsor
I just got tired of waiting for someone faster. I have plans for something else. I'm like a boxer moving up through the weight class. I just need to get my weight up a little higher before I have my first bout.
Keith is now The Man. He now wears the crown and the bullseye on his back!
Old Jul 19, 2005 | 11:24 AM
Noyzee's Avatar
8 second mod
with the driver mod alone its good for 11.5. lol
Old Jul 19, 2005 | 11:30 AM
Slowhawk's Avatar
LS1Tech Sponsor
In the fall this will run 11.3 at 3650lbs which say's alot about the Combo. A Cam change or head change will more than likely screw up the car and wouldn't be worth the $$.
This car litterally drives like stock and runs mid 11's
Old Jul 19, 2005 | 11:33 AM
Noyzee's Avatar
8 second mod
chances are pretty good the kid will have no money to do anything with it anyway
Old Jul 19, 2005 | 11:48 AM
badpewter-z's Avatar
LS1TECH Sponsor
this car runs 110% perfect only thing id change the oil every 3000 or so . runs/drives stock . you can cruise the car at 1200rpms with the a/c freezing your ***** off. and still has more with seat time and cooler weather . as stated before if the heads or cam was changed itd open up a can of worms . the car has been the same since it was put together over 2 yrs ago . if we were all so lucky to get it right first time around.
as for his wife im thinking she was beating him all night for actully selling it.
Old Jul 19, 2005 | 11:49 AM
PurEvl's Avatar
100 shot brad...DO IT
Old Jul 19, 2005 | 11:56 AM
Tracer X's Avatar
LS1TECH Sponsor
No truer words have ever been written! She just looks at me and shakes her head. She's even mean mugging me too!
Noyzee's Avatar
8 second mod
you think i wouldnt spray it?? lol
i have spray on everything. i'll do it.
swapping the cam and springs would screw up nothing.
Boris had a H/C setup for 40K miles!!!! he never even changed the plugs. it went 11.7 at 3800 pounds. seat time would have gone 11.5 no problem. make it 3500 and better weather, who knows.
but like i said, he wont have money to swap anything
Old Jul 19, 2005 | 11:59 AM
Rhode Island Red's Avatar
Tracer... say it ain't so The Mass Pike Revenuers near springfield are going to miss you driving the NBM Z28
Knowing you it's a vette or a Goat
