convo pros
You really only need to put like 12 per tire, 6 per side right? That seems like what most people have. Did you have to put a tube in the tires after screwing them like that, or was silicone on the screws during installation enough? I assume teh tube is nessassary.. but what stops the screw from popping thru the tube? I've never actually done it myself before.....
easy way to tell if your spining the tire on the rim is mark them before you run with a sharpie and see where the lines are at the end of the day .
I'll most likly have the tires mounted and screwed by someone that know s what they are doing.. no need to screw up an expensive pair of bogarts, regardless what I paid for them. I just gotta find someone that car do it.
Steph might know.. does Jannetty do stuff like that?
