Clutch advice...
Went to pick it up at lunch break and didn't make it out of the driveway. In reverse all of a sudden the bastard locked up.
Threw it in neutral and there's some grinding that comes and goes. Put it in first and sometimes it will make it to the end of the driveway fine, other times it makes some massive noise/binds up.
I'm hoping it's not the tranny. If I push the clutch in with the car in neutral it moves forward slightly.
Sooo I need a clutch. I was going to put the F14 cam, etc. in this weekend, but obviously that would have led to bad things.
So should I go for a Spec 3 or what?
I guess I'll go with the Spec 3. But I'm building a new motor/turbo setup with a new tranny this winter anyways.
Either the pressure plate has fallen apart, or the clutch is not disengaging.
I honestly can't figure out which. Anybody ever had any hydraulic problems with the 01/02 updated system?
I'm going to try and give Don a call and see if he has one in stock.
