Dynojet Wideband Commander
Does Don sell those? I saw one on E-bay for $450, but I'd rather get one from Don. Don deserves some parts money. ****, so far he's only gotten me for labor.
This output is designed to control the ground circuit on a relay system. The software is configurable to control the circuit based on 1, 2, or all 3 of the WBC inputs. Here's an example, lets say you have a nitrous oxide system on your vehicle. You would tie the "Programmable Relay Output" wire into the wire that provides the ground for the relay on the nitrous system. The WBC software allows you to define the logic as follows - "if TP is greater than 3v, and if RPM is greater than 3k, and A/F is less than 13.2:1" - then go ahead and provide a ground path for the circuit. If you would like to simplify this logic, you could just say - "if RPM is greater than 3k" - then go ahead and provide a ground path. There are many different strategies and logic available with this provision!
http://www.widebandcommander.com/faq.htm#5
http://www.widebandcommander.com/index.aspx
