Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
best route, nj to ct
Old Sep 19, 2007 | 03:01 PM
cbrrmike's Avatar
Default best route, nj to ct
all you ct guys that come race down here in nj, or vice versa, i need some help....
i need to get from trenton nj up to ellington ct and all the directions ive been looking at want me to take the george washington bridge and the cross bronx expressway.
i plan on making this trip on a monday morning so traffic will most likely be hell and i was wondering if any of you guys use a route that avoids the city without adding a lot of miles or time to the trip?
Old Sep 19, 2007 | 03:57 PM
JL ws-6's Avatar
Race your car!
You can go across on 684 to I84, but that generally takes a good bit longer from personal experience.
Unfortunately going up I95 is pretty much is the most direct way. Right up I95 north to I91 north, follow until you get to the I84east exit and take I84 east to the vernon Rt83 exit, which I assume is hwo mapquest is sending you.
If you leave at an hour that will put you thru the GW bridge before 6 am (I know that's early, but it will get you to ellington around 8:30 to 9 am) I sould do that, then on your way home you will be going thru NY at about noon time depending on how long you're there, which will avoid alot of the traffic going the other way. I have done this ride many times to go down south for some reason or another, and I can tell you the timing of hitting NY is 90% if it, 10% is luck.
Old Sep 20, 2007 | 11:47 AM
9T9BlueTA's Avatar
Garden State to 287 over the TZ bridge and from 287 you can decide to take the Merrit Parkway or 95. The Merrit and 95 intersect with each a couple of times.
Old Sep 20, 2007 | 11:58 AM
PewterScreaminMach's Avatar
I just came home this way yesterday and it worked out great (I often have to come home from Newark and PA from work). As long as there are no accidents on 287 you're golden (maybe about 10-15 minutes longer than going 95 to Palisades and then to 287 and the Tappanzee, but that's only if 95 traffic isn't backedup for miles near the George Washington Bridge, which is usually during peak hours).
Check 880 am on your way up to make sure there are no accidents on 287 and you should be golden (880 does traffic reports every 10 minutes on the 8s, ie 7:58, 8:08, etc). I highly recommend the Merrit Parkway over 95 at least 95% of the time, as well (unless you are driving in very off-peak hours). Haha, POST RESULTS.
Old Sep 20, 2007 | 12:18 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Your a funny guy
So am I
Old Sep 21, 2007 | 06:40 AM
ws6on19s's Avatar
287 to the hutch which turns into the merritt prkwy to I91 to I84....dont take 95 its a parking lot
Old Sep 21, 2007 | 11:54 AM
DarkJuggalo's Avatar
i usually take i-95 south to i80 west, and i80 east ti i-95 north back home
but i go to island dragway so i dont know where u r really at compared to that =-)
