Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Electric theromstat wont turn off
Old Nov 4, 2007 | 04:01 PM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
Default Electric theromstat wont turn off
I have an electric baseboard heater.
I am using a line voltage digital thermostat. I replaced the turn **** one (it was always on 100% or always off).
I can get the thermostat to turn the heat on but I cannot get it to turn off when the room reaches the set temperature. If I turn the electric on to feed the wiring, the heat will come on right away, even if I have the thermostat set to 50 and the room is 70. It wont turn off.
Any ideas?
Old Nov 4, 2007 | 04:34 PM
Humanitarian
I just figured out that my baseboard heaters are 120 volts and I have a 220 volt thermostat. It still turns the heat on but not off, is the 120 volt line causing the issue or is that separate from not being able to turn the heat off?
Old Nov 4, 2007 | 07:20 PM
Slowhawk's Avatar
LS1Tech Sponsor
Your an ***.
"Don't worry Don,I'll call you to see if you have time to come over"
Old Nov 5, 2007 | 07:54 AM
Humanitarian
You said you had work so I was waiting to see if you had time to come over. I thought you would call if you could, otherwise you were too busy. mis-communication there on my part, DUH.
Old Nov 5, 2007 | 10:06 AM
WJ SOM SS's Avatar
Well, at least you didn't try to use a 24v thermostat, Joe.... Best wishes. WJ
