Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Tuner Needed - Code 1336 Crank Relearn
Old Apr 5, 2008 | 11:32 AM
451stroker's Avatar
Default Tuner Needed - Code 1336 Crank Relearn
After assembling my LS1 with a new timing wheel, crank sensor, and PCM, I'm getting code 1336 (Crank Relearn). Apparently, this is normal if you've changed any of the above components. Does anyone have a scanner who would be willing to come to Valley Stream, Long Island, NY 11581 to run the test and calibration on my car? The car will not be drivable for a couple of months and I would really like to solve this problem.
BTW - an OTC scanner does not have the capability to perform this recalibration. It needs to be one of the more expensive scanners like a Tech II or an LS1 tuning program.
Please respond with you price.
Thanks.
John
Old Apr 5, 2008 | 08:59 PM
Kaltech Tuning's Avatar
PM'd you.
Old Apr 5, 2008 | 11:33 PM
massls1guy's Avatar
The efilive 'scan only' tool sells for $250 and can do some interesting things including the crank relearn. I've only had it a few months but I love it, great tool.
