Florida Members Fun, sun and LS1's
Flycutting
Old Oct 16, 2008 | 10:44 AM
fauslpss's Avatar
Default Flycutting
I was hoping that someone could do me a huge favor, I need to flycut my pistons and I really have no way to get the motor to someone. If someone is able to come to my house and help I would be eternally grateful. I can do it this Thursday or this Sunday. Again thanks to anyone willing to help. I live in Nokomis which is south of Sarasota.
Thanks Eric
Old Oct 16, 2008 | 11:10 AM
fauslpss's Avatar
I just need the exhaust side done
Old Oct 20, 2008 | 11:33 PM
92slowmaro's Avatar
to bad your not around orlando or id flycutt them for you.
Old Oct 20, 2008 | 11:44 PM
mnypitZ's Avatar
How hard is it to do this? How do you know how much you need to cut? Come to Deland? I am thinking of doing a TSP MS4 and my heads are shaved .030. I was gonna go with an MS3, but they tell me that it wont work with my heads, so if I gotta flycut anyway, I might as well go all the way. My current mods are in the fquick link in my sig.
Old Oct 21, 2008 | 05:13 PM
92slowmaro's Avatar
its not hard at all you just need 1 intake valve and 1 exhaust valve and a old ls1 head. first find out how much piston to valve clearance you have to begin with and look up how much piston to valve clearance is safe. then you flycut the piston until you have enough piston to valve clearance but do not cut more than 90 thousandths into the piston or else the piston will not have enough material on it to be safe. pm and ill go into more detail.
Old Oct 21, 2008 | 10:04 PM
mnypitZ's Avatar
That sounds complicated
What if I allready have the heads on the engine. I have a 98 with 98 cnc heads shaved 030. I want to get the biggest cam available to produce max HP. I drive it about once a month, so thats it.
Old Oct 21, 2008 | 10:07 PM
TheLS1Kid's Avatar
The heads have to come off to flycutt.
You use a spare head as a guide.
Old Oct 21, 2008 | 10:11 PM
92slowmaro's Avatar
yep heads have to come off. and what makes you think the biggest cam is going to net you the most hp/tq?
Old Oct 21, 2008 | 10:29 PM
mnypitZ's Avatar
OK that is not what I meant. I want to put a cam in that will net the most RWHP and TQ. Seems to me that people running the MS3 and MS4 are running huge numbers on just the cam. If I can fit one in my car with the mods I have I would think the hp would be up there.
Taking the heads off is not a big deal. I can have them off in a couple hours. I have a stripped spark plug hole anyway, so that gives me a chance to fix it.
If you have a suggestion, please let me know. I am just playing around with cam ideas right now.
Old Oct 21, 2008 | 10:39 PM
92slowmaro's Avatar
talk to someone who can guide you to a few good choices for what your goals are as well as intended use of the car. call up some of our sponsers.
i have a torquer v3 its nice, its fun, but not the greatest cam.
Old Oct 21, 2008 | 10:44 PM
mnypitZ's Avatar
Working on that, but they are sticking to cams that dont need flycutting because I cant do that myself. If I could get it done, that would help in the specing of a cam. If you can do it, I can suggest it to FMS and TSP and Thunder to get a cam speced
Thanks
John
Old Oct 21, 2008 | 11:01 PM
waterbug1999's Avatar
I cut mine ~.085".. I run the X3 cam and Dart 205s milled to a 59cc with .040" gasket.
I talked with LGM and thats what they recommended. They do it all the time with the AFR's, they have the same valve size as the Darts. So, its the same.
I did it myself in the car as well. I rented the cutting tool from LGM and knocked it out in a day and was good to go.
Old Oct 22, 2008 | 06:11 PM
TheLS1Kid's Avatar
I recommend a new rear end gear ratio with a cam the size of an MS3 or MS4.
My 233/239 is a little sluggish down low with 3.42's, an MS3 is a little bigger than mine and an MS4 is even bigger than that. Just something to think about.
