Florida Members Fun, sun and LS1's
Oil Pump
Old Dec 26, 2008 | 12:23 PM
HoTrOd HaRrY's Avatar
Default Oil Pump
I believe my oil pump took a turn for the worse. My oil pressure wont go passed 40 even when floored. Could it be the Oil Pump and and advice on changing it
Old Dec 26, 2008 | 01:32 PM
kwiksilverz28's Avatar
It can be the oil pump. Can also be the sender, the main bearings, blah blah. Gotta do some diagnostics...
Old Dec 27, 2008 | 12:31 PM
Ntimid8r7's Avatar
I had what I believe to be an oil pump failure and it cost me my motor. I had no noise or hesitation believe it or not. Didn't even overheat, I just happened to look down at my gauges which I do every few minutes or whenever I look in my mirrors and I watched it go from 60psi to ZERO and no sooner than I got it into neutral she was done. I had my tops off, radio turned off and I was just cruisin about 60. Locked up tighter than church p*ssy.
Old Dec 29, 2008 | 11:38 AM
slowmofo's Avatar
I know thats freaking tight
Old Jan 5, 2009 | 05:54 AM
Mullet's Avatar
GM sending units are well known to go bad in about 5-6 years of use. Get a direct gauge reading first to check this before tearing it down for a pump.
