Florida Members Fun, sun and LS1's
New problem....help please
Old Feb 7, 2009 | 02:38 PM
stock302mustang's Avatar
Default New problem....help please
i have found the noise and its in the radiator.. it sounds like air pockets and sometimes its worse than other.. I put my had on the tanks of the radiator and i can feel it bubbling but its not overheating etc..
Old Feb 7, 2009 | 02:57 PM
92slowmaro's Avatar
take your car to a performance shop that is an ls1tech sponser or to a dealership.
Old Feb 7, 2009 | 04:10 PM
blk/slvr02ss's Avatar
Burp the Rad.and let the air bubbles out and see if it makes a difference.
Old Feb 8, 2009 | 06:08 PM
new belt, new water pump,new thrmosata.. still acting like air in system after bleeding.. my heat does not blow hot even when the car is overheating????
Old Feb 8, 2009 | 06:42 PM
How many mile's on the motor ?Could the head gasket be blow were it is putting compression in a water jacket ?Maybe take it and have a radiator flush done at a shop w/ the flush machine.
Old Feb 8, 2009 | 07:14 PM
flushed the radiator all day today and seems to flow fine.. last night drove car to ocala and on way home i stepped on it to pass someone and bam started to overheat.... belt is still sqealing so whats the chance the tensior is going bad and the belt is slipping on water pump
Old Feb 8, 2009 | 07:36 PM
You have a new belt right ? So the squealing is most likely the tensioner and under load the belt is slipping on the water pump pulley.
Old Feb 8, 2009 | 07:44 PM
its over heats just sitting in my drive way.. sucks i threw a 150 dollar waterpump at it.. atleast if its not the tensioner i can take that back..
Old Feb 8, 2009 | 11:14 PM
9000th01ss's Avatar
I've seen transmissions overheat and it boils around the cooler in the radiator tank.
Otherwise the rest was normal temp.
Old Feb 9, 2009 | 02:23 PM
TheLS1Kid's Avatar
Its probably a head gasket.
Get one of these-------> http://www.automotive-diagnostic-too...v%20560000.htm
You take the radiator cap off and install this tool. Let the car run and pump the tool. If the fluid in the tool changes color that means it has detected combustion gases in the coolant.
