Florida Members Fun, sun and LS1's
need frenders roled
Old May 2, 2009 | 12:59 PM
92slowmaro's Avatar
Default need frenders roled
well im finishing up my 28x12.50-15 install and need the frender roled. if anyone knows someone with a fender roller, or where i can go to have them roled let me know.
ryan
Old May 3, 2009 | 01:42 PM
JohnHF's Avatar
ive used a baseball bat before. put it inbetween the fender and tire and just roll it around pushing out on the fender using the tire as the leverage point
Old May 3, 2009 | 10:48 PM
torquejunky's Avatar
just raise the car, stick the bat in the front part of the wheelhouse, in between the tire and quarter, lower the car and slowly roll the car backwards while someone holds onto the bat very tightly
Old May 5, 2009 | 08:47 PM
thndrracer's Avatar
nothing about that sounds smart
Old May 5, 2009 | 09:39 PM
kwiksilverz28's Avatar
They have done it that way for decades.....
Old May 5, 2009 | 11:37 PM
Just trying to save the dude some coin, if you google baseball bat fender rolling I'm sure there are a myriad of how-to guides along with a plethora of videos. If done carefully and with a heat gun (or hair dryer) to gently heat it up, you won't even crack the paint.
Your other option is to pay just about any big body shop a minimum of, oh IDK 100 bucks and they will do it for you, most likely with a bat or floor jack handle. Or, if you really like spending money, you could even even drop 2-4 bills on your very own fender roller and use it once.
Old May 19, 2009 | 06:09 AM
JEB99TA's Avatar
Any of the Speed shops should be able to reccommend someone with a roller. I think you should be able to rent one from another member here ... maybe Pep Boys or AutoZone in a couple of their locations.
Old May 19, 2009 | 06:18 AM
toadzq8's Avatar
I got a fender roller coming if you can hang on for a couple of weeks
Old May 19, 2009 | 04:55 PM
92slowmaro's Avatar
i ended up renting the fender roller tool from a member on here. it came out pretty good... now for some rear coil overs and i should be ready to go...
Old May 20, 2009 | 05:12 PM
JEB99TA's Avatar
Car's lookin' like deep 11's Ryan ... good luck with it, man.
Old May 20, 2009 | 05:24 PM
92slowmaro's Avatar
definately. and i havent even sprayed it yet! but i may switch cams and mill the heads some. i found out my dad is getting a c6 zo6 at the end of the year. so i gotta be able to keep up with it
