A/C help!!!
going to have it looked at this weekend hopefully and go from there, it sucks having a car just sit there.
i do a/c for a living.. if you looked down and that compressor is spinning.. its shot.. unless you have a bad blend door which is super rare on these cars.. I would me more than happy to take a look at the car if your in the apopka area for free and tell you what you need.. i've done a few ac systems on this board.. truth is everyone can sit here and guess and not a single person could be right..
the condenser should NEVER get cold.. it should get hot as it is pre orfice. the accumulator is nothing but a desicant/filter.. it would have to be super fubar for it to cause you to stop cooling..
as i have said before.. the v series compressors on these cars are JUNK.. they are variable displacement and love to blow metal clear through the system.. so 90% of the time replacing the condenser us necessary..
I am a wholesale distributor for a/c delco /delphi / motorcraft/ denso etc.. if you need parts let me know.. and if you need a hand working on the car i guaruntee you i will be far cheaper than any shop..
do not and i repeat do not put a reman compressor on your car.. it will bite you in the *** from the word go.. even acdelco realizes they don't work as there is no oversize piston kit avail on the market for the compressor so once they hone the cyl they don't seal worth a ****.. unless they didn't hone the cyl.. then well they shouldn't be remaning compressors..
Mike
