Florida Members Fun, sun and LS1's
trouble installing LCA relocation brackets
Old Aug 20, 2009 | 09:20 PM
vdubbing337's Avatar
Default trouble installing LCA relocation brackets
I am in the process of lowering my car and I figure I'm going to do it right so I bought Strano springs, Umi adj PHB, anf LCA brackets, well the brackets are a pain in the **** to get on, how are you suppose to get them past the bracket for the brakes, these are bolt in ones, I had to bend the brake bracket out and slide it in, unfortunately I was only able to get the bolts back through the side closet to the tire, has any one else ever had this problem? I doubt the bracket will move with the bolt only through one hole and not both, but was wondering if there was a trick to it?
Old Aug 20, 2009 | 09:28 PM
B02SS's Avatar
You have to cut part of the brake bracket off.Once tightened up,it's fine.
Mine came with instructions from BMR,but I also did a search in the
suspension section and found pics in there.Good luck.
Brian
Old Aug 21, 2009 | 03:03 AM
thats what I was thinking, mine came with no instructions at all.
Old Aug 21, 2009 | 07:41 AM
UMI Performance's Avatar
If they are our brackets they should have been supplied with instructions. If they are our brackets and you didn't get instructions please e-mail Brad at brad@umiperformance.com and request them, he will e-mail them over.
Thanks!
