Differential help ASAP Please!
Furthermore, as I am driving, there is a loud shuddering from the rear end whenever I am slowing down.
What parts do I need to order besides a new ring gear, and what is the name of the part with the bolts in it?
Thanks,
Dana
If you didn't know this already it is highly reccomended that the parts are installed by a professional or someone of equivelent knowledge. If not it will cost even more in the long run when the gear set whines loudly or you have premature part failure.
Where are you at? If you are close just come pick it up if you think you need it.
Also someone correct me if I am wrong, but it looks like some one has been in
there before. Your main caps look to be studded, I thought those were bolts.
