Florida Members Fun, sun and LS1's
Gainesville tonite
Old Oct 30, 2009 | 02:34 PM
  #41
pittman's Avatar
Originally Posted by Bret@EFIAlchemy
We can take care of that, arent you leaving soon?
Be down tonight. I have about 4-500 lbs in the bed to hold it down so we can do a 1-2 shift and remain on the road. Bringing the Hoosiers as backup !!
Old Oct 31, 2009 | 03:07 PM
  #42
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Hope you get it done Pitt! We can line up sometime soon
Track was hooking Wednesday night (1.422 on the 275/60/15 radials)
Old Oct 31, 2009 | 08:34 PM
  #43
pittman's Avatar
Derick, was that using a 2 step ? What psi is hooking for you ?
We didn't get her done yet. Still blowing by second gear into the limiter. I had to bail about 11:30 last night. My kid was an hour and a half out of Tallahassee and hit something metal in the road. Took out the rear tire and rim. You wouldn't believe the rim damage !! Looks like an axe hit it at 100 mph !! Never seen anything like this !
Pitt
Old Oct 31, 2009 | 11:08 PM
  #44
7 Second Club
Pitt,
Sorry to hear about the bad luck on both fronts. Hope both can get fixed up soon!
The 1.422 was off the transbrake at 3000 rpm, and I also had a 1.439 off the footbrake. Both gave decent wheelies, but the TB 1.422 was an eye opener! I also had a 1.459 off the footbrake with a little chatter (that pass was my last of the night around 10). 18 psi seems to work good for me, but I know people that have tried more and less depending on weight and such.
Derek
Old Nov 1, 2009 | 06:50 AM
  #45
pittman's Avatar
Pitt,
Derek
Thx man, me too ! Going to take my drive shaft in Tuesday to see if that is causing my vibration. It's the original shaft so I am hoping it is tweaked a little and will fix my problem after a good balance job.
You have one hell of a good suspension on that car.
Old Nov 1, 2009 | 04:44 PM
  #46
02NBMFormula's Avatar
Originally Posted by yellowbird1232
He waas running the 98 camaro grey with flames on the front. The SS would get off the line at all. 2.4 60ft all night. The third run the damn t/c was acting up. It came on even though it was showing to be off. Looking into tires for it now, that maybe what was messing with the t/c on the launch.
have you tried pulling the tcs fuse? ive heard of the tbss's doing the same thing.
Old Nov 2, 2009 | 08:22 PM
  #47
pittman's Avatar
Derik,
Dropped off drive shaft this morning. I think my pinion angle is way off as well
Pitt
Old Nov 3, 2009 | 11:21 AM
  #48
7 Second Club
Hope you get her back into shape soon, racing weather starting to get better
Old Nov 3, 2009 | 12:49 PM
  #49
pittman's Avatar
Derik,
Do you have experience with a scavenge pump ? I know you need some positive crankcase pressure. I need to take care of this excessive crankcase pressure problem. I was told 15-20 hp from the relief !
How do you not remove too much pressure (adjustable)?
How do you hook the pump up to an LS motor ?
Is the valvecover breather then removed ?
Pitt
