Florida Members Fun, sun and LS1's
looking for help near orlando
Old Mar 15, 2015 | 09:00 AM
CFLFORMULA93's Avatar
Default looking for help near orlando
Can anybody recommend a repair shop or mechanic or members with experience with the lt1 fbodies? Most places Ive found wont touch It or are really expensive. Ive been doing work to it myself but limited on knowledge and tools. I have a 1993 formula a4 with bolt ons giving me a hard time.......
Old Mar 15, 2015 | 03:23 PM
JimMueller's Avatar
You can try Dynasty Auto, 407-896-8700. I know the owner (Chi) and lead tech (Bill) from autocrossing. It's where I take my car for any maintenance or service I don't want to perform myself. They are about a block away from the intersection of Colonial & Semoran.
Old Mar 31, 2015 | 12:42 PM
95sscamaro's Avatar
what are you looking to do?
Old Mar 31, 2015 | 08:01 PM
My car has died on me. Im getting no spark. Ive changed the opti icm coil plugs wires. ive been throwing parts at it and I need some help. I dont have a multimeter or scanner nor the knowledge to diagnose electrical problems. Any help?
Old Apr 7, 2015 | 12:47 PM
95sscamaro's Avatar
have you checked and cleaned all your grounds? by any chance do you have battery relocation?
Old Apr 7, 2015 | 04:54 PM
Yeah ive went through all wiring I dont see any corrosion or loose connections. No battery is in stock loc checked fuses dbl checked opti install/plug wire routing ive tried 2 different opti on my 2nd coil icm is new I thought I damaged my memcal do I replaced that im running a g1 adapter and a mail order tune....I think the problem is in the ecm
Old Apr 8, 2015 | 12:12 PM
95sscamaro's Avatar
id pull the ecu and check that none of the prongs were damaged in install of the chip
