LT1/SBC valvetrain stuff cam, rrs, springs etc etc Up for grabs is a whole complete brand new valve train at a low low price of $750 plus shipping. Originally bought for an aluminum head LT1 cam setup. My buddy ended up wrecking the car, now the parts are for sale. Over $1400 worth of stuff Heres what is included: Click on the pics for high res. ARP Cam Bolts Part Number # 300 - 1001 http://www.miamistreetracing.com/upl...am01_thumb.jpghttp://www.miamistreetracing.com/upl...am02_thumb.jpg ARP Hex HeadBolts Part Number# 134 - 3601 http://www.miamistreetracing.com/upl...ad01_thumb.jpghttp://www.miamistreetracing.com/upl...ad02_thumb.jpghttp://www.miamistreetracing.com/upl...ad03_thumb.jpg ARP 12 point Intake Manifold bolts Part Number # 134 - 2101 http://www.miamistreetracing.com/upl...ke01_thumb.jpghttp://www.miamistreetracing.com/upl...ke02_thumb.jpg ARP Oil Pump Driveshaft Part Number # 134 - 7901 A must have since the stock couple is PLASTIC! :( http://www.miamistreetracing.com/upl...il01_thumb.jpghttp://www.miamistreetracing.com/upl...il02_thumb.jpg ARP 7/16th Rocker Arm Studs Part Number # 134 - 7103 http://www.miamistreetracing.com/upl...ds01_thumb.jpghttp://www.miamistreetracing.com/upl...ds02_thumb.jpg CompCam/Combination Motorsports Hydraulic Roller Custom Grind Duration: 224/236 @ .050" Lift: .536/.556" with 1.6 Roller Rockers LSA: 114 + 4 degrees advance built in Lobes: 3314S/3316S I made 35x/38x with this same cam with iron heads stock valves. http://www.miamistreetracing.com/upl...am01_thumb.jpghttp://www.miamistreetracing.com/upl...am02_thumb.jpghttp://www.miamistreetracing.com/upl...am03_thumb.jpg CompCams Superlocks 10 degree +.050" locks Part Number# 614-16 http://www.miamistreetracing.com/upl...ocks_thumb.jpg CompCam Beehive 10 degree Retainers PartNumber# 795-16 http://www.miamistreetracing.com/upl...rs01_thumb.jpghttp://www.miamistreetracing.com/upl...rs02_thumb.jpg CompCam Beehive Spring Seats Part Number# 4705-16 http://www.miamistreetracing.com/upl...ts01_thumb.jpghttp://www.miamistreetracing.com/upl...ts02_thumb.jpg |
CompCam Beehive Valve Springs Part numbe# 26915-16 http://www.miamistreetracing.com/upl...gs01_thumb.jpghttp://www.miamistreetracing.com/upl...gs02_thumb.jpg Crane Gold Race 1.6 Roller Rockers for 7/16th stud Part Number# 11755 - 16 http://www.miamistreetracing.com/upl...ne01_thumb.jpghttp://www.miamistreetracing.com/upl...ne02_thumb.jpg 2 NorthStar Coils and 2 ballast. 1 resistor/ballast has a broken connector but works. all you need is 2 more coils to compelete this coil setup. http://www.miamistreetracing.com/upl...ls01_thumb.jpghttp://www.miamistreetracing.com/upl...ls02_thumb.jpghttp://www.miamistreetracing.com/upl...ls03_thumb.jpg Delteq Opti Direct Module. Cost $200 alone brand new. This is the Brain. All you would need is the wiring harness, bracket to mount the coils, and spark plug wires. I was quoted $2xx for everything else. http://www.miamistreetracing.com/upl...le01_thumb.jpghttp://www.miamistreetracing.com/upl...le02_thumb.jpg Felpro Headgaskets .039" Part Number# 9966 PT http://www.miamistreetracing.com/upl...head_thumb.jpg Felpro ThrottleBody Gaskets, injector O-rings, misc http://www.miamistreetracing.com/upl...kets_thumb.jpg FelPro Timing Cover Set Part Number# TCS 45956 http://www.miamistreetracing.com/upl...ng01_thumb.jpg Isky Adjustable Guide Plates Part Number# 200 - AGP These are completely adjustable, unlike those GM/comp/crane pieces which never seen to work right. http://www.miamistreetracing.com/upl...ky01_thumb.jpg Ferrea Valves 2.02/1.57* valves Not sure what part number they are. I believe they are stainless steel. http://www.miamistreetracing.com/upl...es01_thumb.jpghttp://www.miamistreetracing.com/upl...es02_thumb.jpghttp://www.miamistreetracing.com/upl...es03_thumb.jpg And last but not least a complete intact Opti Harness. http://www.miamistreetracing.com/upl...tcor_thumb.jpg I just went on summitracing and I entered all the partnumbers I have, and i came out to: ***************$1064****************** That is without:
So you are saving at least $500. All parts are Brand New unless noted $750 plus shipping Paypal Perfered |
you just barely made the 6 month requirement ;) |
yeah, i know... i've been reading this board for almost 2 years, even though i don't have an Lsx based anything.... I'm on a lot of local boards. most of the Fbody guys know me as NorySS. :) |
© 2024 MH Sub I, LLC dba Internet Brands
