Florida Members Fun, sun and LS1's
Need some block info please.
Old Mar 8, 2007 | 08:13 PM
Oldsmobility85's Avatar
Default Need some block info please.
I have hear some casting numbers off the block that i picked up this week in the start of freshening up my 388 inch stroker SBC it is 13to1 on 6inch rods and makes roughly 550 horse at flywheel on motor. Kinda mild by the way heads and camshaft wise. But was wondering if this block is inferior at all to an oldschool 60s and early 70s block like some people will swear are the strongest but the main caps are more rounded and smooth than an older blocks seeming to b a better idea in my oppinion. This work horse is a very low end quick revving engine that turns about 7000 rpm usually and will have somewhere around 150 or 200 shot. Anyone have any usfull information for me based on the info i placed below. THANKYOU
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear
seal, "Hecho en Mexico"
Old Mar 9, 2007 | 05:06 AM
Steve68's Avatar
Its a low HP replacement motor from GM made in the late 70's/80's nothing to right home about, have a machine shop check it out,
Check Mortec site out full of GM block and head no's
Old Mar 10, 2007 | 02:54 AM
bumperdragging's Avatar
they make a manual called " ziggy's small blocks " its a manual with every small block casting number coded out, it has alot of info, i think you can order it from jegs or summit. my ziggy's, unfortunately, is buried under piles of rod pieces and spun mains but ill try to dig it out and check for you.
Old Mar 10, 2007 | 08:13 AM
Steve68's Avatar
you nailed it, exactly what the mortec site says,
Old Mar 10, 2007 | 12:57 PM
Thats what im saying i got that info from mortec but i think i might just short fill the damn thing its going in a g body and cooling in these things isnt much of an issue and ive had a short filled block in it before and it did fine.
