Florida Members Fun, sun and LS1's
>>>>>>>>>>General Banter<<<<<<<<<<<<
Old Jun 22, 2007 | 11:41 PM
  #261
FASTERthanYOU's Avatar
You guys missed the greatest movie I've seen in a long time! 1408 is genuinly scary and an amazing story! 10 out of 10
Old Jun 23, 2007 | 12:00 AM
  #262
staringback05's Avatar
im not also convinced on the pump, much rather have the belt driven system also i believe a guy posted info on the weight and it was only like an 8 pound difference...not enough to approve the hunderds of dollars for one
Old Jun 23, 2007 | 09:15 AM
  #263
02silvaZ's Avatar
TOMORROW!
Old Jun 23, 2007 | 10:05 AM
  #264
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
i want to run the iron block because down the road i will probly spray or boost it as far as rods right now im looking at scat rods and maybe mahle pistons or diamond. ill be sticking with the ls6 intake and p&p tb, with a set of p&p 853 heads and a custom bump stick by patrick g. ignition will probly be truck coils and my 10.4 wires, im keeping the stock cooling system for now unless i remove the ac and go with a truck manifold turbo kit.
Old Jun 23, 2007 | 12:44 PM
  #265
Are u gunna make me a sig or what jacob?
Old Jun 23, 2007 | 01:45 PM
  #266
you got some good pictures?
Old Jun 23, 2007 | 02:44 PM
  #267
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
Originally Posted by Eurospec2
i would not run fast 90/90, thats 1200 bucks that can be much better spent elsewhere for more power (unless not on a budget)
Hence the last bit part. It could be better spent (power wise) on n20, but I don't know if Rob wants to spray or stay N/A. But it is definately at the end of the line budget wise, other things are more important.
Balancer, meh, i decided against it, i like my charging system and water pump to much to do this for such a small gain, now i would get an SFI approved dampner that is not underdrive for track use
The ATI is just that. The one like I have is not underdrive, it is stock diameter. The ATI race balancers are $420 and the best money can buy. Stock balancers have come apart, causing damage to other parts. I'm not sure about f-bodies, but in c5 the steering rack is the victim, or in a blown application like mine the head unit bracket would be the victim. Pinning the crank does not help, because the stock balancer can actually come apart. I got a good look at a c5 supercharger bracket that was damaged because the stock balancer (pinned) simply came apart. I decided to spend the $$$ for piece of mind.
Can't wait to hear that MS3 coupe.
Old Jun 23, 2007 | 02:48 PM
  #268
will82's Avatar
Originally Posted by bluenyghthawk
i want to run the iron block because down the road i will probly spray or boost it.
I would recommend running pistons with a slight dish. This way you could initially run smaller combustion chamber heads and still have a good compression ratio for n/a. Then later if you go FI, the heads can be swapped for something with 72cc-76cc combustion chambers. Those combined with the slightly dished pistons will make for a great boost compression ratio. This way you don't have to change any internals to change between n/a and FI.
Man I wish I had the $$$ for a forged bottom end.
Old Jun 23, 2007 | 02:52 PM
  #269
will82's Avatar
Rob,
I just remembered I still have an F-Body ATI damper that I never returned to EPP. They initially sent me the wrong one and I had to re-order a y-body damper. If you're interested in it for your build, I'll let you have it dirt cheap. It's of course brand new, and was only removed from the box and slid onto my crank, at which point it didn't fit properly and we knew it must be the wrong part. It's a stock diameter 6-rib balancer.
Old Jun 23, 2007 | 03:49 PM
  #270
LS1Tech Sponsor
will it make any difrence on my 347 i have n my car now power wise?
Old Jun 23, 2007 | 05:22 PM
  #271
will82's Avatar
honestly probably 1-2hp at best, just because the unit is so precise. Other than that it's a quality/safety issue, not a power mod.
Old Jun 23, 2007 | 05:27 PM
  #272
will82's Avatar
http://www.atiperformanceproducts.co...s/damchevy.htm
http://www.exoticperformanceplus.com....html?item=859
Old Jun 23, 2007 | 10:45 PM
  #273
02silvaZ's Avatar
to everyone who didnt go to sonics tonite, i would like to say 'screw you', i was stuck up there with a bunch of rice, 1st time i get to come up there and no one is there, bastards!
Old Jun 24, 2007 | 03:20 AM
  #274
^^^ huh?? i was up there till 1030....and travis and mark where there after that
Old Jun 24, 2007 | 06:11 AM
  #275
02silvaZ's Avatar
i was there from 8-8:30, nuttin but rice, so i left
Old Jun 24, 2007 | 08:18 AM
  #276
ls1amit's Avatar
you definitly went to early bro. Anything before 9 is the rice show.
Old Jun 24, 2007 | 09:22 AM
  #277
yea me and travis got there around 930
Old Jun 24, 2007 | 09:50 AM
  #278
LS1Tech Sponsor
i skipped the whole sonic thing went straight to 17 last night went 1-2 got "390"hp vorteced mustang by a half a car, ran a 415hp goat got beat by 1 1'2 cars and ran a 06 z51 vette and he got me by a 1 1/2 so the t/a did alright for the night. but we got to watch a bunch of really good races so it was fun
Old Jun 24, 2007 | 10:03 AM
  #279
i went out yesterday and took some pics when the sun was going down of the car right after i washed it.....went out there to cecil on the other side of normandy where its just roads for miles......nice pavement, practiced on my launchs with crappy tires
Old Jun 24, 2007 | 08:42 PM
  #280
02silvaZ's Avatar
man it was so hot today, those mich light drafts sure were smooth going down, good choice of eats Jacob, food was great, beer was great, and very affordable too!
