Car problems
It seems my car has an intermittent problem, ESPECIALLY when it rains. I had my clutch/flywheel/transmission checked out and they are all 100% ok, so it's not a drivetrain problem. The car will sputter and hesitate, almost as if it was being "choked". At speed, the car will hesitate, with the same symptoms. It only happens from 900RPM - 1600RPM. Could this be an electrical problem from a wire getting wet, or is my fuel pump on the way out? My gas gauge is busted, but I don't think it is linked to all the sputtering.
Also, the driver's side EGR valve is "fluttering". I was told by the good guys at FX Ceramic Coatings that there is too much air being pushed into there, yet the original gasket is in there (the one with the tiny hole), and I made sure I really bolted it down tight, but to no avail. I have the block off plates in my apt, but I haven't had time to remove the EGR system and put them on. Any ideas on how to stop the flutter until then?
Thanks a lot.
Also, does anybody have any idea on how to fix that damned flutter on the driver side EGR?
As for the AIR fluttering gimmick, just yank that useless crap, trying to fix it would take longer than just getting rid of it all.
