Florida Members Fun, sun and LS1's
KrisXpc DYNO
Old Jul 7, 2007 | 10:31 AM
LS1BirdDRG's Avatar
11 Second Truck Club
Don't get caught up in making peak power numbers your goal here. I've seen alot of 98's give up the ghost when you spin them too much.
My Formula sees 6600 but if it was a stock bottom 98 I'd keep it under 6400 and avoid the rev limiter. Now my 04 LS6 car I used to have sang the 6800+ tune for awhile. Of course, this is just my opinion since I don't have spare motors falling out my **** either and I know you get your paychecks from Uncle Sam just like I used to......
Get those torque numbers up!
Old Jul 7, 2007 | 11:43 AM
bluecajun5.3's Avatar
Originally Posted by 2000badbird
why is the tq so low? stock most ls1's put down more tq than that
b/c that thing is starving for fuel
sorry but 117% IDC won't last very long
Old Jul 7, 2007 | 12:19 PM
hpmotorsports's Avatar
Don't worry, that was just a starter pull,lots of work to be done,thanks jason
Old Jul 7, 2007 | 01:03 PM
383LQ4SS's Avatar
Why is the injector DS so high?
Old Jul 7, 2007 | 01:52 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
stock injectors if you read it says he needs to get new ones before he can tune it
Old Jul 7, 2007 | 02:46 PM
Eurospec2's Avatar
i think what he means is the stock injectors should not be that high
Old Jul 7, 2007 | 08:09 PM
383LQ4SS's Avatar
Stock injectors should handle that power all day long. I am sure HP motorsports has looked at it. Most likley need a fuel pump. Id try measuring fuel pressure at the rail during a dyno run before changing injectors.
Old Jul 7, 2007 | 09:05 PM
LS1BirdDRG's Avatar
I'm still running DOCs original 28 pounders on mine off his 98 and they work fine for my cam only.
Kris are you still running that Weiand intake you had before?
Old Jul 7, 2007 | 09:09 PM
MPHmotorsports's Avatar
I doubt that car would have made any more peak power then what the graph shows had the dyno operater stayed in the pull till 6600RPM's.
If so maybe 1 or 2. The dyno shows 6200 RPM's, and this is at or very close to where peak will happen. Very rarely will a setup even with a large cam make peak past 6300-6350.
Also I agree stock injectors should be 100% fine. Pump must be dead. We have tuned a number of A4 cars making well over 370 with stock injectors.
My personial car made 400RWHP in a 98 with the injector duty cycle at 97%.
Anyways, good luck with the combo and tune.
Enjoy the new power.
Old Jul 7, 2007 | 09:39 PM
We have alot of things we are doing with the car .This was just a starting point. Thanks Jason
Old Jul 7, 2007 | 11:07 PM
aight...
let me know when/if yall get it straight so i can get a piece of it.
4400# blue against the black loud mouth.
Old Jul 8, 2007 | 12:18 AM
  #32
ls1amit's Avatar
I bet with some more fuel and maybe some timing it will peak out at around 6400 rpm. 6600 would be a good shift point in my opinion.
Old Jul 8, 2007 | 12:53 AM
  #33
Eurospec2's Avatar
Default loud
Originally Posted by bluecajun5.3
aight...
hehe i want the leftovers
Old Jul 8, 2007 | 03:54 AM
  #34
staringback05's Avatar
he likes to be refered as "whomp whomp"
Old Jul 8, 2007 | 09:02 AM
  #35
02silvaZ's Avatar
"womp womp", spit sputter, "womp womp"
Old Jul 8, 2007 | 11:10 AM
  #36
i don't think they'll be any left.
+ you need to concentrate on a black Z, lol...
Old Jul 8, 2007 | 11:57 AM
  #37
good luck
Old Jul 8, 2007 | 12:07 PM
  #38
KrisXpc's Avatar
