So I got some problems....
saw I was losing some coolant, system was clogged with dexcool, thought maybe it was related to the thermostat, pulled it ran no thermo, flushed the cooling system. Drove a bit, car didn't overheat, but it stalled out. I towed it home.
Started car was running rough, but I had the EGR unhooked at one point(getting to thcermostat) so just a small intake leak.
I pulled the radiator checked it, and saw it was leaking. I replaced it, cleaned everything up put new fluid in changed the oil. Started it up, its knockin, shooting smoke/fluid up out of the radiator(car is dead cold) and found puddles of coolant under the car wherever there was a seam in the exhaust.
I think popped a headgasket, possibly cracked a head, and probably spun a bearing...
this sux.
