99 LS1 motor, Convo Pro's , WElds, NXL DP, N2o stuff,
The wife is pregnant and I am trying to open a Surf Shop by Nov. so I need to move some stuff ...
Used NX NXL Direct port kit for sale its the one that plugs under the injectors with a fuel accumulator, Purge noid, about 16ft 4 an line high polished 10lb NOS bottle , MSD window switch, NX 3 switch panel for a F-body as well this is a complete kit 900.00 shipped
If you dont need the bottle, purge,feed line,Window Switch or switchs the NXL kit will be 600.00 Here is the link from when I got the kit
https://ls1tech.com/forums/lsx-parts-sale/703182-nxl-kit-part-out.html
2 - New Dyno Tune Nitrous noids 50.00 each
2 - Used NOS Supershot NOS noids 45.00 each
1- Big NX N20 noid 95.00 Used for purge about 5 times
1/2 tall Valve cover spacers for 99-up LS1's 80.00
MAF Translator 50.00
4 Used 15x10 Weld Draglights less then 3k on one pair and the other pair has about 10 track passes all four have a 4 1/2 backspace 240.00 a pair long lug nuts are included McGuards @ that
Centerline Convo Pro's no tires 15x10 with 3 1/2 Bs and a 15x7 up front. Wheels came off a 1969 Camaro 450.00
Used 4.10's with shims and crush coller and new pinion bearing like new about 2k on them they were in a friends car and he went to a 12 bolt. Plus 2 qts of fluid and poss additive only thing really needed for instal would be a gasket ! 110.00
Back up 1999 LS1 motor short block has about 45k on it. ARE Heads 0 miles on them, ARP head bolts, F11 cam ..... sold
All prices do not inclued shipping My cell # is 772-519-0989
