Need a CAM!!!!
Old Oct 24, 2008 | 11:14 AM
V666's Avatar
Default Need a CAM!!!!
I am building a Lq4 stock setup with a pt-88 turbo with a t400 and ford 9" ina G body. Car ran 9's with a buick stage 2 V6. I need to figure out a good cam for this setup on pump gas and only needs to be hardly streetable. Right now it has a 5500 stahl converter which needs to be replaced so I will get what I need as far as stahl for the right cam. I would like to see high 10's on the pump gas, but will settle for 11's any help is greatly appreciated
Old Oct 24, 2008 | 01:44 PM
98Z28MASS's Avatar
So the lq4 is utilizing a completely stock shortblock? If your looking for a big FI cam Exotic Performance Plus has one on their website that they use on a lot of their FI setups. Otherwise you could look into one of the many FI cams offered by board sponsors. If your looking for great Idle quality you could always look into a GT2-3 Cam from lingenfelter or something similar to that spec wise.
