Second 2 Bar Map Sensor gone bad.....
Old Oct 24, 2008 | 09:51 PM
AFASTYZFR1's Avatar
Default Second 2 Bar Map Sensor gone bad.....
I have had two GM 2 bar map sensors (off of supercharged Cobalt) just die on me.......both brand new........getting code p0170 and car runs like **** because all my fueling is based off this sensor.......I checked voltage from pcm and it is fine.......any ideas
After putting in new sensor it takes alot of driving and many hard pulls before sensor dies.
Old Oct 24, 2008 | 10:24 PM
CTSV_510's Avatar
You're voltage is OK? Did you check the ground?
Old Oct 24, 2008 | 10:44 PM
AFASTYZFR1's Avatar
Yea....I am sure it is the sensor......I tested the output from the sensor at atmosphere and it is reading around .1 volts and it should be around 1.5v
I am going to try the other style map sensor.....maybe the meth has something to do with it, or the silicone I used to seal sensor to intake....I have no idea
Old Oct 25, 2008 | 11:31 AM
AFASTYZFR1's Avatar
I used black silicone to hold it in, not sensor safe......would that really damage sensor?
Old Oct 25, 2008 | 05:22 PM
Reject's Avatar
i think so, it says it's not sensor safe
Old Oct 25, 2008 | 05:52 PM
AFASTYZFR1's Avatar
I am going to try a new one with sensor safe rtv but don't see how the regular black silicone can damage a map sensor
Old Oct 26, 2008 | 05:07 PM
DeltaT's Avatar
When they say 'sensor safe' it is refering to the oxygen sensor, because some fumes can damage the sensor tip. No reason it should affect your MAP.
Jim
