How much boost will a stock 6.0 handle?
Old Nov 7, 2008 | 10:52 AM
digitalsolo's Avatar
I'll be putting 12-14 lbs on my heads/cam 5.3L, with meth and an intercooler on 93 pump.
Katech rod bolts, ARP head/cam/main bolts, ported/shimmed oil pump, LS2 chain, etc, but still stock GM pistons/rings/rods/crank. We'll see how long it lasts.
Old Nov 7, 2008 | 12:30 PM
BLNLS1/RX7's Avatar
Originally Posted by js2fst
So you can make more rwhp with a stock 6.0 than a stock Ls1?
The 6.0 iron block which I am switching to this winter with all forged internals should be able to with stand 20lbs. of boost without any issues.At least I hope so.
Old Nov 7, 2008 | 03:29 PM
Moz's Avatar
Moz
Check Sig.
This is with the crappy 3" Dual ProCharger Intercoolers.My IAT's are low and I have no detonation!
Old Nov 7, 2008 | 04:45 PM
GT67METHV's Avatar
how much boost can a stock 6.0 handle?
the world may never know. lol
i would say 2-3psi. less than it had be4 it popped.
Old Nov 7, 2008 | 07:10 PM
js2fst's Avatar
I don't care about a built one questioning a stock one.
Old Nov 8, 2008 | 12:36 AM
67Firebird455's Avatar
Yes, a stock LQ4 will make more power than a stock LS1, this is manly because 1, the heads flow better, have larger chambers, and dished pistons (LQ4, not LQ9), so with a static comp of less than 10.25:1, you can add a bit of boost with more timing. Run 10psi, 12-13psi with meth, and call it a day dude.
Old Nov 8, 2008 | 12:37 AM
BTW - Spend the $350-400 on a turbo profiled cam, it will make a world of difference if you're planning to run the piece of crap that comes in the LQ4.
Old Nov 8, 2008 | 10:36 AM
js2fst's Avatar
what about the rods and pistons if that is the case why not put my ported 317 heads on and add boost, but rod bolts and pistons won't hold with meth and 02 zo6 cam. But would the 6.0? say 600 rwhp area?
Old Nov 8, 2008 | 11:40 AM
hellbents10's Avatar
LS1Tech Sponsor
No need to spend big money on a cam, stock ls6 cam works great. Check sig the stock 6l's are fairly strong.
