spool time
Old Nov 12, 2008 | 02:05 PM
Chris'stransam's Avatar
Default spool time
I am building a 408 for boost, and i am gona use a Gt88 turbo. I wanted to know what rpm will i be when i get 10 to 15 psi . What kind of power do u think it will make . This motor will be it a 99 ta m6. I havent realy pick a cam yet for it
Old Nov 12, 2008 | 02:24 PM
otherwhitemeat's Avatar
around 4000 you'll get 10 psi.....600hp
Old Nov 12, 2008 | 02:50 PM
Is the gt88 to big for the street and strip?
Old Nov 12, 2008 | 05:49 PM
No it's not too big....
Old Nov 12, 2008 | 05:54 PM
DrTurbo's Avatar
LS1TECH Sponsor
The GT88's will be on full boost by 4K or before with a 408 . 14psi will be into the ~800rwhp range.
Old Nov 12, 2008 | 05:56 PM
67Firebird455's Avatar
What gear are you running with that 6 speed? I think you'll have a tougher time with it being a 6 if you're running low gears and a short tire. If you were running a stalled rig, with taller gears/tires, it'd load the turbo more, thus creating more boost earlier in the curve. You won't get 10psi in 1st gear if you're running like 4.10 gears and a 26" tall tire with that 6.
