Forced induction head gaskets
Old Nov 16, 2008 | 06:20 PM
1fast bird's Avatar
Default Forced induction head gaskets
What kind of head gaskets would you guys recommend for forced induction?Cometic or Gm mls gaskets?
Old Nov 17, 2008 | 04:59 AM
EPP's Avatar
EPP
We typically use the GM MLS head gaskets. Bob
Old Nov 17, 2008 | 09:53 AM
cookba's Avatar
do you use the GM MLS head gaskets for all your engine builds regardless of displacement and hp output? just curious.
Old Nov 17, 2008 | 10:42 AM
MY99TAWS6's Avatar
I am running the gm mls ls7 head gaskets on my afr 225s and 408 . Cometic would be my choice if have any trouble with these ls7 head gaskets. I am hoping the ls7 can take up to 20psi max but likey won't need to go past 15psi to hit my power goals.
Old Nov 17, 2008 | 10:55 AM
EPP's Avatar
EPP
Yes we do for the GM blocks. On the Warhawk blocks we used Fel-Pro. Bob
Old Nov 17, 2008 | 12:33 PM
pwrtrip75's Avatar
I used the cheap felpro stock replacements. A light coat of engine enamel on them and put together while tacky. Once baked on you'll never get them apart.. 15psi + nitrous for 3 years now and never an issue.
