Turbo owners please chime in...
Old Sep 21, 2003 | 02:33 AM
Jammer's Avatar
Default Turbo owners please chime in...
looking for solid 10's now ...with forged bottom end.
CAS?
Robs QMP?
Anybody else have other "available " options.
The Incon owners seem to put up good numbers but with Incon gone..what are some of the other options... best options.
DaZeD AnD CoNfUsEd
Old Sep 21, 2003 | 10:24 AM
Warbird's Avatar
Default Re: Turbo owners please chime in...
Since you car is an auto any of the kits you mention should easilly put it in the 10's with a good bottom end.If you haven't already built your bottom end, make sure you make the right choices on fuel, pistons and heads etc. with FI in mind from the start. Turbos tend to make a ton of torque so I would seriously consider beefing up your driveline as well. If your driveline is fairly stock, it won't last long especially if your planning on running on a good tire.
The most important part of building something like this will be your budget. There are a lots of hidden cost's in a turbo and tons of gotcha's along the way. None of these kits are bolt on power and modifications along the way are the norm, not the exception.
Before buying a kit I would do some research into what's available on the market. You might even want to give Garrett and PTE a call to get their opinions on what works and what doesn't. For me I called them after the fact however I was able to pick up some quality information. Hopefully you have a quality tuner not to far away as a good dyno with wideband and a tuning program are critical.
If Mightymouse still has his kit it would probably be a good buy used.
Good
Old Sep 21, 2003 | 12:06 PM
SS00Blue's Avatar
A ten isn't a problem on a stock bottom with the right tuning and a smallish single, like a T-63.
A nine is just a T-74 away from that.
NOOOOOOOoooooooo problem for a forged bottom!
SC-
Old Sep 21, 2003 | 01:54 PM
Jammer's Avatar
Thanks guys... Tuning would come from one of the NJ shops. I;m gonna do a rear, but not till I waste this one...which wont be long so I'll have it ready.
I'm working w/ about 10k max for the turbo set up, installed and tuned. That may not make it from what Im seeing.
